How much stronger Stainless Steel over mild steel
So I have a M15 shaft some where between 35 cm and 45cm long. Off centre will be a cassette mount , there will be 2 bearings and then a wheel at each end. The total load it has to carry is approx 90 kg.
Will M/S be strong enough ?
How much stronger would SS be ?
I think it kind of depends -
Base mild steel likely won't be as strong as stainless, but if what you have is some kind of grade meant for shaft use,
then it's probably alloyed and / or has a higher carbon content, which will make it stronger than SS, and maybe easier to machine...Maybe.
OTOH, an M15 shaft of either is probably strong enough.
Stainless steel, almost as many types as non stainless steel, each with own capacities.
The only advantage "normal" stainless steel has over steel, is the rust-avoiding capacity.
The big disadvantage . Galling.
Sorry couldn't post a picture from laptop :-
Like this
So, the overhang is 6"or so?
Here is math and theory to determine deflection, but it's way past my pay grade, so I couldn't begin to tell you if it would help:
Here is a calculator, but you must input the properties (modulus of elasticity) of the steel in question:
Are you excited yet ?
