So laying in bed contemplating my navel I realised I had wangled another trip to the Netherlands and yet again I faced going with a python that was barely adequate.
The current ride was lacking in low gears and had a poor high gear ratio mainly due to the front mech control become unresponsive.
So easy you say new cable and some adjustment and we are good to go ?
Well actually no the problem is more I have a 28T - 38T - 48T driving a vanilla 14T - 28T cassette , so maximum gear inch spread is only 45gi
The hills are so steep around here I need a 1 : 1 low gear this means there is almost no top gear without the front mech then stopping working
However due to the kindness of Popshot I have a N360 CVT hub which has a maximum gear inch spread of 55gi enabling me to still have a 1 : 1 however
I would gain the equivalent of 3 more gears at the top end , single changer and being able to change whilst stationary.
So yes there is a downside the WEIGHT they are an eye watering 2.5kg !!!
Much guidance has and will be forth coming from DannyC who already uses a N380.
So the mis guided plan is to refurbish the front end on the old #5 [ which is actually based on the first Python I built 10 years ago ], try to lose some steel and not worry to much.
It is after all a tourer , I am currently almost that amount over weight and if I made the rear able to carry my camping gear so not towing a trailer it should be win , win , win ?
This is the front end , it is very tired from being used over several winters and receiving almost no maintenance for a couple of years.
Although oddly the gears work better than the one I currently ride !
Total weight as pictured [ no brake levers ] is 10.25 kg
Mainly rust and neglect.
Despite every thing this still worked , although the lower jockey wheel is very very stiff.
Least the wheels have some teeth on them.
This was the one it replaced , so some way to go yet ......
Only kidding rescue cable parts and off to the bin it goes.
