Hi Paul.
It is still not clear to me if the V2 Tilting mechanism is actively powered or simply provides a "lean lock" devise which holds the vehicle and rider upright while moving slowly and at stops.
Hi Paul .Simply a lock , if you watch closely the video where he gets into the new body and set's off his left leg is just visible walking it along until he gets some speed up to put that leg also on the pedals ?
Well that's my take on itYMMV
You know you want one![]()
If Aerotilt is a free tilter, than my understanding is that it must lean over quite a bit more than a Direct Tilt Control trike to achieve an equivalent roll over resistance. This might explain why it is tilting so much in the tight corners. Although this is part of the fun on "out of the way" roads, it might prove less than ideal in more congested urban areas where roadways and intersections are more difficult to bank to accommodate higher recommended speeds.Err no , no use for my rides.
Interesting to watch the perceived visual horizon and the tilt angle , hard to guess tilt angle from visuals.
he's braver than me , there was a huge amount of debris on the road @about 2mins
