Well don't tell ANYBODY I have driven the pedal car ! Red tarmac is outside house
gray tarmac not outside the house a round trip of 280 meters ! Of course done the Zombie way with no brakes and no gears.
A new problem has reared it's ugly head [ this time created by me
] I made a cassette mount for the half shaft using a collar with 2 x M6 grub screws , they are not able to stop the mount slipping despite only having a 38T front ring , does not bode well for racing !
Solutions ?
Well the people on the pedal car forum suggested either:-
a) grind a flat on the shaft
b) drill some 3mm pockets in the shaft
c) drill all the way through and use a cap head M6 & lock nut
Suggestion c) seemed to avoid all this trouble in the future so after talking to DanyC to bolster my confidence I set to last night.
Well that did not go well at all !!!
I removed the offending collar and noticed there was barely a mark where 2 grub screws had clawed their way around the axle providing sporadic forward motion for 3 x 280 meters ?
Drilled one of the collar holes through the other side to M6 and used the other grub screw to locate it.
Then applied the M6 drill through the collar hole and into the shaft , after a minute I removed the collar to see the progress ..yes you guessed barely a scratch , there is a shiny mark about as big as you would expect from a centre punch.
So another set of plans needed !
1) Buy some carbide tipped drills and have another go myself
2) Take it and it's partner down to a friend who owns a local engineering works and ask him for some help drilling them both
3) Take them and the length of M17 shiny mild steel steel rod I have and have my engineering friend copy the 2 Samagaga half shafts
thus leaving this problem behind for good.
That does involve turning the wheel ends down to M15 for the hubs then turning the end further down and threading M10 for the retaining bolt.
Also drilling 4 holes for M6 bolts to retain 2 x disc mount and cassette adaptor and a locking collar.
I think 10 probably is not guaranteed to succeed and failure could render the Samagaga diff unusable , which is a shame it looks a nicely
made unit.
2) requires the least work on my friends part , I do have some browny points with him and there should be enough.
3) Good solution IF I though I might keep the car , so probably the best in the long run for the car and I ?
Thoughts ...
