Hi, I am building a warrior, but instead of following the drawing I am using an 28" rear wheel. And this seems to initiate a bit of a problem. I hope some of you can give me directions to solve this in the easy way.
As you can see in the picture I have created some sort of jig to create the dimensions according to the drawings. 5" and 11" wooden blocks give support.
The corner between the rear seat tube and the center boom is 135 degrees (or 45 degrees) as mentioned in the warrior pdf. Due to the changed angle between rear fork and rear seat tube, caused by the rear wheel being 28" instead of 26", the 45 degree "fish mouth cut" in the top of the rear seat tube won't match the rear fork. See picture 2.
So, probably the fishmouth has to be changed to fit the rear fork. Does any of you know (by experience?) what the right corner is that has to be cut out on top of the rear seat tube? Or an easy way to derive the right corner?
Thanks!
Best regards, Kiezel
Thanks!
