My 3rd Chopper Trike Project
This time I'm going to attempt a rear mono shock.
This is the bike that would tempt me to break out the welder ?
never found any more pictures of it ?
Mono front and rear and suicide brake ?
I think the challenge will be the front fork ?
How to make it strong enough for the loads ?
I though of a 3mm wide central spine welded in place through holes in the outer tube ? or a inner tube ripped up it's length and hammer into the outer and plug welded through holes in the outer ?
However how to deal with the bend ?
graucho
Minnesota, Twin Cities
Great progress! Its really taking shape. You can see the finished bike in your head now can't you.
Most loading is over the rear wheel, so even a single 2" EMT conduit tube or similar should hold up.
However the original seems to be the same diameter as a normal fork legs looking at the top ? so 1" or 11/4" ?
My chopper with 2 x 1" legs flex considerable giving a nice suspension effect ?
