Streetfighter Quad Questions
georgia usa
Hi
Have a few questions about the streetfighter I was thinking of using it s the basis of a velomobile
  1. Wheelbase?
  2. Wheel size? Is it 20" wheels?
  3. Track (the overall width with wheels)?
  4. Are the above adjustable to a degree?
Hutt Valley, New Zealand
Hi
  1. Wheelbase?
  1. Wheelbase will depend on your height. Plan explains how to set the overall length (and therefore wheelbase) based on your leg length.
  2. Yes, 20 inch wheels. For a non-leaning bike (i.e. 3 or more wheels) these are stronger than bigger wheels.
  3. Track: I can't recall without looking up and hesitate to publish plan details publicly. A quad can be narrower than a trike without sacrificing stability and the Streetfighter is narrower than the AZ trikes.
  4. If you're building it then you can adjust whatever you like, combine bits of several plans, etc. Recommend that you don't adjust the shape of the wheels - round seems to work best :)
On the old forum, Fantom's nephew is a great velomobile based on the Streetfighter:
There are also several YouTube videos for Fantom's Nephew.
Regards, Neville
georgia usa
I can buy the plans this week then sounds like they are adjustable to fit what I want. The body is just a shell no real structural value
I am mostly basing it on the Model T Bulldog aftermarket body of the early 1920's without the fenders and yes, the wheels will be round
georgia usa
looking everything over, needing to order some more plans, but I am leaning towards a delta trike configuration with a simple carbon fiber body over it. Either the Aurora or the Delta Wolf probably the Aurora. The Streetfighter seems to add needless complication to a Velo that a trike doesn't have.
My plan is to build the trike than carve the body out of foam blocks over it, cover the foam with carbon fiber epoxy mix, then remove the foam. The drawings are more of a guide than anything.
